Scaling is procedure that meticulously removes contamination toxins, micro-organisms, plaque, tartar, cementum, dentin that is rough and/or permeated by calculus from around, below and under the gum line down to the bottom of the pocket. This is done to remove biofilm, calculus, and toxin down to the bottom of each periodontal pocket in order to obtain a healing response.
Root planing involves smoothing the root surfaces of your teeth with thin curettes so gum tissue can more firmly reattach to roots that are clean and smooth to prevent tooth loss and sensitivity problems. The procedure makes it more difficult for plaque to accumulate along the root surfaces.
4 个回复
aiwen681219&&
toto&&
三个人的空间&&
三个人的空间&&
